Gear Shift Calculator Link
Análisis de datos de deportes de motor profesionales
Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
1851 Vistas
The 'Gear Shift Calculator' link in the 'Gear Changes' module, leads to a blank page... at least it is when I click on it.
Is fixed now Callum, thanks for letting us know 🙌
Hi Tim, thanks for the sheet.
Am i the only one having issues with my low powered 1.3 N/A with a close ratio box and 7800rpm rev limiter? I'm getting unrealistic change rpms...
Thanks
Hi Armaki, send me a link to your sheet if you want. I can take a look to see what's going on.
Hi Tim, there you go.
Thanks!
  • Micra-K11_Hewland_RaceCraft-Gear-Shift-Calculator-v1.1.xlsx
