Hillclimb Start and Finish Lines
Análisis de datos de deportes de motor profesionales
Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
1742 Vistas
Hi,
Is it possible to add (separate) start and finish lines to already recorded data in i2? I was at a local hillclimb on the weekend shaking down the new car and would like to be able to set laps so that I can overlay and compare my 4 runs with variance channel etc.
https://www.youtube.com/watch?v=_NCPyhDCG50
Cheers,
Ryan
Open the logged data in a Rally Workspace. It allows you to set stages, that should be what you want.
Yep, rally workspace works great. Thank you.
I just put my cursor over the section where distance travelled first moved and hit stage marker + put in the time for that run.
