i2 issue
Análisis de datos de deportes de motor profesionales
Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
2096 Vistas
For some reason the track map and track report built in components are not showing anything in i2 Standard.
The data I am viewing has Glong / Glat, and the GPS map is working. Also probably related "section times" are not calculating
Not sure if there is an obvious thing I am missing here.
Thanks!
Hi Jordan,
This is usually down to a problem with the track definition - usually easy to solve though!
As shown in the image below, go to the green "track" button on the top left. In the dialogue, click generate track. There you have options to generate by GPS or Distance & Lat accel. I recommend distance & lat accel when possible. You can see in my example the lat accel channel is red meaning the software doesn't know which channel to use. Just click on the options for the channel selection and select your lat G channel, this should sort it.
The other possibility is your Corr distance channel isn't working. You should be able to solve this in a similar way by going to "Tools > Corrected speed and distance" as shown in second screenshot.
If that doesn't solve your problem, feel free to send me the data and I can take a look myself. tim@racecrafthq.com
