Reference Cursor
Análisis de datos de deportes de motor profesionales
Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
1122 Vistas
Hi,
In Webinar 286 a reference cursor is used to find the delta between. What is the shortcut to add a 2nd cursor? I had a look through the manual, but must be blind as I can't find it.
Cheers,
Ryan
Hi Ryan,
In webinar 286 the data is being viewed in i2 Pro. If you are using i2 Standard you won't have this functionality.
Ah, bugger. Thanks!
