suspension histogram
Análisis de datos de deportes de motor profesionales
Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
2513 Vistas
Hello all!
Im going through some of the data lessons and want to pull up a suspension histogram to follow along but i can't seem to set up a worksheet like in the lessons. Is this only an option for I2 PRO users?
Is there any way to view damper performance using I2 standard?
You will need math channels to properly do suspension analysis. I2 Pro is the answer -- absolutely worth it.
