T2 telemetry missing data from LD file data stream
Análisis de datos de deportes de motor profesionales
Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
1055 Vistas
hello,
I am trying to get my T2 up and working on the bench before we head to a race later next month. I have T2 feeding into I2pro and working well except four channels. The channels that I am having trouble with are four shock pots that were recently added to the car. These are logging at 500hz with anti aliasing enabled to get good clean data(we race in offroad). These are the only four channels that I have personally set up in the C187 dash as we work with a manufacture that did most of the leg work on set up. I can't help but feel like I missed something in set up or am logging inappropriately for telemetry.(keep in mind that this is just replaying a log file and not actually over the cellular data stream that we will eventually be using.)
Any help would be much appreciated.
Thank you,
Shawn Schumacher
Okay, I figured it out! I had a math channel set up in i2 that adds a coefficient to get the actual data as the data stream wouldn't let me put anything in that was greater than 12". The math channels were only being applied to logged data and not the telemetry.(its a box that needs to be checked when setting up the math channel). The data was there, I just wasn't looking at the actual channels.
