AWD SR20DET going into an RWD chassis
Cómo graduar una leva
1990 Vistas
Have scored a very cheap AWD SR20DET, plan is to put it in an e30 with a 5 speed rwd sr20 box.
Getting conflicting info on the block differences but I understand it is the same bolt pattern as the SR20VE that HPA are running in the SR86. I can manage everything else that is different but dont want to jump too deep if tbe box will never work.
Question is, what was involved to get a rwd box that would fit. Does your box run the standard RWD SR20 bellhousing?
