cam adjustment
Cómo graduar una leva
1981 Vistas
how i can find right adjustment 1mm measurment , when i dont have cam specs. I have opening degrees, duration and closing degrees
If you could list what information you do have, in full, and/or the camshafts' manufacturer and grind numbers/IDs, it would help a lot.
Some aftermarket ones, especially when mild, are designed to be a direct swap for OEM and use the OEM marks.
