Cam degree wheel
Cómo graduar una leva
1420 Vistas
Greetings, after finding true TDC by diving whatever degree number you get aren’t you supposed loosen the degree wheel and turn it to the TDC reference point (marking ) on the degree wheel ?
Hello yes or move your pointer
Regards Ross
