Cam timing
Cómo graduar una leva
2043 Vistas
What if you don't have a cam card ? Or Cam card information is not the same as in your examples ? For example i got a 4g63t thet i am currently building. The customer got his own cams and they are HKS 274_ 278 (part number 22002-AM011) and the only information HKS provide is Duration , Valve Lift, and Designed Valve Timing 110 degrees for both cams and thet is it. No information @ what lift it has to be measured.
HKS cams do not require any sliding sprockets - they can be installed at stock timing marks.
