Cam timing-no specs
Cómo graduar una leva
1620 Vistas
Hey. I’m asking if a pair of cans can be dialed in without knowing the cam spec info.
All I know is it’s a Sr20ve 20V pair of camshafts..I hope!
Anyone can help?
Most aftermarket camshafts, especially mildly up-rated ones, are fitted using the standard timing marks, with vernier adjusters being for fine tuning.
Are there any casting, stamped numbers or codes on the camshafts - often aftermarket will have it on the end opposite the sprocket/gear.
