Camber Castor measurement tools...
Cómo graduar una leva
2161 Vistas
What do people use to measure Camber and Castor when doing a string alignment? Searching the Bay of "E"s I notice there are loads of options, upto hundreds of dollars worth of electronic toys... What works? Minimum viable vrs what you actually like to use?
Any thoughts?
Cheers
Cam
Hi Cam,
There are a few different camber/caster gauge options out there. This particular tool is one that we use here:
http://www.longacreracing.com/products.aspx?itemid=1798&prodid=7218&pagetitle=Caster-%2F-Camber-Gauge-w%2F-Magnetic-Adapter
Tim
