dialing in vct
Cómo graduar una leva
1930 Vistas
just watched making cam timing adjustments, my question is how to dial in the intake cam on an rb25det with VCT how would you make the adjustments
With VCT you will need to know how the cam manufacturer defines how the cam should be degreed. For an intake cam this would be normally in the fully retarded position. It's recommended to also check your clearances at the fully advanced position just to make sure you have sufficient piston to valve clearance.
No worries, thanks for clearing that up
