E85 with out flex sensor.
Cómo graduar una leva
5483 Vistas
Hello would it be safe to run E85 race fuel on my drag race only VW golf MK2 R32 turbo with out a fuel flex sensor.
The reason I ask this is you can't get pump E85 here in the UK but I can get race fuel e85 and I believe this race fuel e85 is consistent .
Another reason is I want to use my table switch function on my ECU to add fuel on my dry nitrous set up.
Thank you for any feed back .
Yes you can run E85 race fuel without a flex fuel sensor. It's safer to do this if you're using a commercially manufactured E85 race fuel as the ethanol content is controlled much more accurately than pump E85. The biggest concern if you're not using a flex fuel sensor is when you're running pump ethanol as this will often vary considerably.
thank you. i thought this was the case. thank you for the help.
