Finding true top dead center
Cómo graduar una leva
1225 Vistas
i just need a better understanding, so after i find true tdc, do i use the pointer after i moved it to true top dead center? Or after i check true tdc do i move to pointer back to factory tdc ? To make my adjustments off of ? Please help for a better understanding
The pointer you added and adjusted to true TDC is the one you'll be using for your cam events. Once it is set to true TDC, you don't move the pointer.
