How to degree a cam
Cómo graduar una leva
1658 Vistas
My question is if I don’t have a adjustable cam gear but have adjustable crank gear with multiple key ways how do I advanced / retard with crank gear you didn’t cover that
Hi Marton basically it is the same way the crank keys are normally in 2 deg increments
Regards Ross
