Measuring Piston To Valve Clearance
Cómo graduar una leva
1360 Vistas
even if i have sufficient valve clearance when i am building the engine doesn't the valve clearance change at high rpm like 4000 or 6500
The clearance should not change provided the valve springs are sufficient to keep the valves controlled by the camshaft.
