SR20VET cam degreeing trouble
Cómo graduar una leva
180 Vistas
What could cause my EVO and EVC points to be pretty far off from the cam card specs. EVO and EVC points aren’t off by the same amount either which I learned on the course is usually a sign the valve lash is off. I have triple checked the lash and even tried setting a little tighter or looser to see what that did. My motor setup is basically identical to the worked example in the SR20ve how to degree a camshaft course. I have gone back many times and made sure true TDC was correct both with dial indicator and adjustable hard stop. I had this issue a while back and couldn’t figure it out and just moved on and since have had the engine running so I know it’s not out of time. However much my open point is off my closing point is about double. Any help I would really appreciate I’ve run out of ideas.
Normalmente respondemos en un plazo de 12 horas (a menudo antes).
¿Tienes problemas con el sitio web?
¿O necesita contactarnos por algún otro motivo?
