TDC came up different each time?
Cómo graduar una leva
1539 Vistas
This may be a really stupid question but I’m a bit perplexed as to why in all 3 times you found TDC in the video using the 3 different techniques why is it that you got 3 totally different results even though the degree wheel was located the same for all 3 examples (or was it?)?
