3D Printable String Alignment System Files For Sale
Compra, venta e intercambio
Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
2335 Vistas
Hi all, I made a budget friendly string alignment system that can be 3D printed. This is just for the files to print. All you need to supply is 1" square tube, a level and strings.
You can head over to https://www.scherzmotorsport.com/product/3d-printable-string-alignment-system/ to check it out.
I also have a coupon code "HPA10" for $10 off until the end of November 2024 as a thank you to HPA and the community for everything you do, and all the knowledge you share! I wanted to share it with everyone here.
Also if anyone has any feedback or improvements I am very open to critique.
Can you share an image or explain how the front horizontal bar is done?
The horizontal bar is made up of a bunch of threaded cylinders. the middle piece has female threads on both sides with all other pieces having a female thread on one side and male on the other. That way you can use any size printer, and it is modular to make it any length you need.
Get bit of work well done
