Best tuner for a 2006 lbs durmax 2500 hd
Compra, venta e intercambio
Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
3143 Vistas
I am literally at a loss when it comes to what to do next on tuning my truck?
Hi Erica, my advice would be to contact hp tuner and have a look at this link https://www.hptuners.com/product/l5p-ecm-exchange-service/
The way i read it you would need to buy this before it can be tuned but i could be wrong
Regards Ross
If your looking to tune your 2006 lbz , then i would highly recomend using efi live. www.efilive.com You can either tackle it yourself or find a reputable tuner to buy a file from.
Depending on what part of the country you are located in someone might be close enough to help you
One thing you need to know is what do you want your tuner to be able to do?
1. Change a switch and get a different tune - What i have on my 7.3 powerstroke, PHP Hydra chip with 9 different tunes and it runs so much better with it especially towing.
2. Complete stand alone tuning which will let you change just about anything.
3. Something else?
EFIlive is your best friend with the LBZ the table definitions are amazing as well as 2D and 3D map interfaces. I have been tuning Durmaxs for a few months now and just got in with a shop and moved states to work for them. If you are anywhere near TN let me know.
