Dyno Dynamics 2WD 450DS Digital Chassis Dyno Rolling Road - UK
Compra, venta e intercambio
Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
3430 Vistas
Dyno Dynamics 2WD 450DS Digital Chassis Dyno Rolling Road + Fan
REDUCED FROM £25,000 + VAT
Removed from our cell ready for collection.
Used for several years with no issues, only selling due to upgrading to a 4WD set up.
We specifically chose the Dyno Dynamics purely because of its accuracy, reliability and repeatability.
Very easy to move around so can be stored in a corner until required.
The dyno itself is capable of handling a total of 2400BHP, axle torque up to 9220ft/lb and a Max speed of 155mph.The Dyno is now dismantled and ready for collection. It can easily be reassembled if you would like to see it working, but we literally ran a vehicle on it, swapped for the 4WD and ran the same vehicle on the new dyno, to verify the power outputs were similar.
The sale includes everything you need to start working.
Dyno
Ramps
Dyno Dynamics Fan
High Spec PC with Screen and Keyboard
Latest Bluetooth Hand Controller / PDA + Cloned spare
We can supply the dyno with the Extra ramps and frame that has Air-Rams to lift the car should you want to have this in a below surface mount setup, like we used to in our cell
DynoDynamics will still support the unit
More info can be found here:
https://www.dyno.com.au/dyno-dynamics/dyno-dynamics-2wd
