Link G4Xtreme Pro (Silver Box)
Compra, venta e intercambio
Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
2601 Vistas
Link G4 Xtreme Pro ECU, serial #10594. E-throttle, onboard knock detection, and full logging enabled. Selling to upgrade to G4+ box. Asking $1000 USD for ECU, turning cable, and mounting plate. A & B connectors or loom not included.
Being that i'm a link dealer it's too pricey for me but why i'm replying is:
Look in the Fury and The Thunder, I have a Fury for my Skyline and a Thunder for my Supra built in knock and wibeband is great the thunder only lets it self down is a few small ways would be good to run 12 injectors staged sequentially so i could run 6 small injector and 6 large injectors, does run out of inputs/out puts when trying to run too much 4l80e and quick spool valve and boost control 4 abs sensor for traction control, but solved it by running a two wire idle control valve
I plan on getting the G4+ Fury ECU when(if) this sells.
is it still available ??
Yes, still available
Great stocking stuffer
