can bus
Comunicaciones CANBus decodificadas
Módulo relevante: Discusión práctica > Empalme de nuevos cables CANBus
830 Vistas
can we use shielded wire for can bus on motec m150
yes you can. The shielding isn't usually required, it's more important that the CAN Hi and CAN Lo wires are twisted with each other. Usually 1 twist per inch is sufficient.
