EMTRON ECU and Haltech CAN WB1
Comunicaciones CANBus decodificadas
1872 Vistas
Good day,
I have a Haltech WB1 CAN WBO2 on hand, and am in need of a CAN WBo2 input for a EMTRON Shadow 8 ECU.
I am not familiar with using can across platforms. I make the bold assumption that I can configure the EMTRON to communicate with the Haltech WB1.
Do I need to contact Haltech to get the CAN Protocol for the WB1 and create a custom Data Set for the EMTRON to use to communicate with the WB1?
Is there already a pre-defined DATA Set in the EMTRON that communicates with Haltech WB1?
This is the EMTRON CAN Channel 1 Config Screen;
And here is the Pre-Defined DATA Sets;
Well, as it turns out Due to the Exchange rate currently, I was able to sell the Haltech Equipment and purchase new EMTRON modules to replace them, I never went through the decoding the canbus protocol for the WB1 and TC2.
