Pay someone
Comunicaciones CANBus decodificadas
1967 Vistas
Hello I have a 350z and the abs/wheel speed sensor and tach and ac &couple other things are run on canbus system and have a aem infinity ecu 8 .. anyone know how to write a firmware how to set up ecu to read 350z canbus? I know there a infinity ecu built for the 350z but I don’t have that one
hello the can file may be available direct from Aem if you give them an email, I know other manufactures of ecus do this
Regards Ross
Tried aem they said they don’t make one and not interested in making one
You cant "write a firmware" for an Infinity. You are probably better using an interface box like this: https://www.wiringspecialties.com/350z-g35-aem-ecu-canbus-module/
I do have that box but when I spoke to WS they said the wheel speed sensor wont work cause the box can’t keep up with it when it spins or sonthing like that ..
