privacy wrong for video
Comunicaciones CANBus decodificadas
1981 Vistas
cant watch video due to privacy setting. How do i change them
Hi Glenn, I'm not sure what I can suggest at the moment. We're all back in the office tomorrow so I'll see if we can get a solution for you. In the mean time just make sure that you're trying to view the videos in chrome.
Hey Glenn,
Lauren has your email and will deal directly with you to get things sorted, but just off the cuff for any others that stumble on this issue in the past it has been caused by workplace or campus network restrictions.
Outside of this, Vimeo is blocked in certain countries but generally it will straight up tell you that rather than giving a privacy setting issue.
Either way, we'll get you sorted, check your inbox for Laurens reply if you're reading this before you've seen it.
