18 AWG into Size 20 Autosport Contacts?
Cableado práctico para deportes de motor - Nivel profesional
1235 Vistas
Question for the hive mind:
Ive read you can use an 18 AWG tefzel wire into a size 20 auto sport contact… however, none of my positioners show it as a selection.
Does anyone do this and if so, what selector are you using on your positioner? One down from 20 AWG?
Yes that is what I do. A pull test will confirm that is sufficient.
