Advice on CAN cable
Cableado práctico para deportes de motor - Nivel profesional
1747 Vistas
Hi,
Anyone knows brand and type for CAN cable (single twisted pair) AWG20 in spec55 or equivalent for motorsport use with a reasonable small outer diameter in Europe? Most industrial types are very bulky.
Thanks Dirk
If you don't want to just twist 2 wires together, you can take a look at the Military Spec no M27500 for cables.
Something like M27500-20SD2T23 would work, but it's a shielded cable.
Last page of this document breaks down how to read the M27500 MilSpec :
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Catalog+Section%7F1654025_Sec9_SPEC55%7F0313%7Fpdf%7FEnglish%7FENG_CS_1654025_Sec9_SPEC55_0313.pdf%7F074911-000
Hope it helps,
Frank
