CAN wires twisted ?
Cableado práctico para deportes de motor - Nivel profesional
Módulo relevante: Habilidades prácticas de diseño de arneses de cableado > Diseño de capas de torsión concéntrica
744 Vistas
Hello, my name is Nat from Thailand.
I have a question about how to twist wires.
CAN bus wiring, if i have a 4 wire branch that contains CAN H/L, 12v and ground for example, for a lambda to CAN module
Obviously the CAN wires are twisted together
How best practice to twist?
2 twists per inch on the CAN wires,
1 or 2 twists per inch on the power and ground if you want, and then twist together to make a neat bundle.
the first line is highly recommended. the second line is purely for cleanliness on the bundle
