Code for wiring documentation
Cableado práctico para deportes de motor - Nivel profesional
1720 Vistas
Could you please explain what does "Code" column means? 3 columns with different colours, what is the purpose for that? Step 3.
My guess is it's referring to the colour coding used on the wiring - the main colour, eg BLue, the trace colour which is a thin line on the main colour, eg BRown, and a possible third colour or number?
For example, injectors may be BL, BR, W (white); BL, BR, R; BL, BR, BL; BL, BR, BR, with the last letters being for colour coded teminals.
