Concentric Design - First attempt at Design
Cableado práctico para deportes de motor - Nivel profesional
1541 Vistas
Good Morning,
Mostly i have been able to arrange my various loom and branches for my car so that the different layers of each branch have the same wire gauge.
However, on one particular branch i have 4 x 18awg, 4 x 20awg and 4 x 22awg to form up. Im a bit lost on the best way forward for this one?
Any tips or pitfalls to avoid?
Cheers
Nev
what are they for? Those look like coils and injectors at first glance, but depending on what they're for can potentially change up where you break out to individual components getting rid of the trunk altogether.
Actually that’s not a bad suggestion, changing to 2 x 6 way connectors rather than 1 x 12 is probably a reasonable solution.
