Connector ID needed
Cableado práctico para deportes de motor - Nivel profesional
1239 Vistas
I need the mating connector for a Bosch 0265006344 wheel speed sensor. These were used on Porsche 911’s from 99-2005 as well as the Boxter from what I understand. This is being adapted to a Porsche 930 transaxle. Attached is an image of the connector on the sensor.
i think you can buy a harness repair kit with the part from Porsche:
https://www.suncoastparts.com/product/996FRHARNESS.html?srsltid=AfmBOooxopZJwyqVTQmhCLo-1j0fxffG5oLOLTWkW63RmBJ3pBBrdGfP
https://www.pelicanparts.com/More_Info/99661296100.htm?pn=996-612-961-00-OEM&srsltid=AfmBOorccmbnCKXNr51iODqROLGcUKGNh8aHG0WAsriqxDA0nnVfiyZ36sM
Personally, I would just convert to using a readily available connector I like to use such as a DTM-2.
The more I looked into this I was coming to the same conclusion. The sensors are inexpensive so I could even make up a spare.
