Crank and cam sensor shielded cable
Cableado práctico para deportes de motor - Nivel profesional
1960 Vistas
Dear friends
I just started planning wiring harness For seadoo RXP 255 turbo charged the ecu will be MoTeC m84.
my question is can I use tefzel five core Shielded cable for both crank and cam sensor signal as they are close to each other and the striped length will be 250 mm.
I attached a picture for the layout.
it is highly recommended to run them as seperte wires
Regards Ross
