HDT-48-00 compatible with Deutsche AS pins?
Cableado práctico para deportes de motor - Nivel profesional
2653 Vistas
I've searched but struggling to find a concrete answer.
Will my HDT-48 crimper work with appropriately sized Deutsche Austosport pins, or is the DMC crimp tool (with appropriate positioner) a requirement. If anyone knows for certain please let me know otherwise I might have to order a couple of AS pins and test it
Cheers, KB
I'm not sure if it is recommended/approved, but I have used my HDT-48 to crimp AS pins without issues, you just have to make sure that you get the depth set correctly.
Brilliant. Thankyou!
