Relay Panel & Batt Killswitch
Cableado práctico para deportes de motor - Nivel profesional
1448 Vistas
I am writing my diagram for my 12v system and I’ve reached a questionable connection.
I am wiring a battery kill switch with alternator protection into my system and my main question is should my main relay/fuse panel power come before or after this kill switch? I know it should be after but then I’m sharing the same hi voltage floating block that goes to the starter with my relay panel.
Does anyone have a diagram that uses the same type 6 post kill switch with a relay panel in the system? Please if I didn’t explain it well I’m sorry.
