Stack ST500 Connectors
Cableado práctico para deportes de motor - Nivel profesional
1905 Vistas
Hello everyone, would anybody be able to help me identify the brand and type of connectors used on this Stack St500 dash please as I would like to make a custom harness for it. The circular connectors on the clock itself are 6/8 pin and the ones on the harness are 4 pin and just push together.
Thanks in advance,
Craig
The rubber connectors are Cannon Mini-Sure Seal. The circular connectors are Deutsch IMC series.
Since you're in the UK Farnell might be a good source:
http://www.farnell.com/datasheets/1722329.pdf
https://uk.farnell.com/search?ost=mini+sure+seal&searchref=searchlookahead&product-range=mini-sure-seal-series
Thanks for the info David! Are you sure about the circular connector though? The two housings on my clock are a 6 and an 8 pin housing and they aren’t listed in the catalogue. Also, the female pins look different. The Deutsch ones are a solid barrel, whereas the ones I have are split to allow them to open up and accept the male terminal.
Cheers,
Craig
Could they possibly be Amphenol LTW BD-08?
Sorry about that, if not Deutsch IMC, then perhaps Switchcraft EN3, if the Amp reference doesn't do it.
https://uk.farnell.com/c/connectors/circular-connectors-components?brand=switchcraft-conxall
Thanks so much, that definitely looks like the one. Much appreciated David!
