Tefzel Wire VS. Crimp Terminals
Cableado práctico para deportes de motor - Nivel profesional
2106 Vistas
Hello everyone,
how are your experiences with Tefzel wire crimping into "standard" wire terminals like Aptiv (Delphi) Metri-Pack or GT, AMP Junior Power Timer, Bosch BDK 2.8 or Molex MX26? Do you use rather M22759/32 or rather M22759/16?
Cheers
Björn
Hello Björn,
Probably a little late for you, but I use /32 with no issue. I just use the smallest/next size smaller wire seals. If you are using AMP Superseal 1.0 contacts, Race Spec make a die set for the Rennsteig PEW12 that is specifically for use with /32 wire.
AMP Superseal 1.0 die set
