the color identification number chart with the shrink tube
Cableado práctico para deportes de motor - Nivel profesional
Módulo relevante: Ejemplo práctico del arnés del compartimento del motor > Step 5 - Following the Construction Plan
1325 Vistas
the color identification number chart with the shrink tubes where did I find this? thanks in advance .
If you're referring to the colour coding for identifying wires in your harness, we use a MIL standard which you can find here - https://nepp.nasa.gov/npsl/wire/wire_color_code.htm
The cliff notes though are below:
0 - Black
1 - Brown
2 - Red
3 - Orange
4 - Yellow
5 - Green
6 - Blue
7 - Violet
8 - Grey
9 - White
