Turbo Speed Sensor - Garrett - Pinout
Cableado práctico para deportes de motor - Nivel profesional
3665 Vistas
It sounds like the kit has a pigtail with wires. Page 12 of the Installation Instructions details what the wire colors are for the pigtail:
Section B: PRO KIT WITH DATA LOGGING, NO GAUGE
(data logger not included)
1.For data logging, connect the orange wire on the pigtail to a +5V DC (±0.5V) source. This supplies sensor power. Your data logging device may have a 5V DC source available. The sensor output signal is carried by the green wire. Connect the green wire to the data logging device on a channel selected for turbo speed signal. Connect the black wire to data logger ground. The red wire is not used; cover the end with electrical tape or heat-shrink.
CAUTION: DO NOT CONNECT THE ORANGE WIRE IF SENSOR IS USED WITH A DATA LOGGER IN ADDITION TO THE SPEED GAUGE
