Wire size and connector choice
Cableado práctico para deportes de motor - Nivel profesional
1162 Vistas
Hi all. Adding either r35 or 1nz coils to my Corolla. Wanting to make a sub loom, Not a Motorsport quality build, and wanting to use deutsch connectors. Can I use the DT series or do I need the DTP. Will use 16awg power wire then spice to 20awg for the sub loom I assume the 13amp rating on the DT should be enough
cheers
DT series is an excellent choice for coils.
