Wiring diagram design app
Cableado práctico para deportes de motor - Nivel profesional
2362 Vistas
Does anyone here know of a good app or program to design professional diagrams?
I want to be able to have a diagram I can include in my documentation. Thanks
I use OpenOffice Draw. Build up a library of connectors you use, and it can make a pretty good diagram. Here is an example of one of mine.
  • Mali-FM-Harness-Layout.pdf
Thanks!! I’ll give it a try!
I do a netlist in excel and a harness diagram in visio similar to David. I then use cells to the right to calculate wire lengths (excess(4") + additional for twisting(20%) etc)
This is all you really need. The next thing which helps a LOT with fixing things, reverse engineering (aka.. original person gets hit by a bus, etc) is an actual wiring diagram. Visio does this well as well.
Ok awesome!
