350Z DBW Pedal and Throttle Body Pinout and Wiring
15565 Vistas
Hello All,
I'm planning my wiring for my sr20vet engine swap into my 240z. I'm planning on using a Link g4x Fury X and Aim PDM32.
I haven't been able to find the wiring pinouts and wire size needed for the 350z DBW throttle and 350z pedal, so I would appreciate if anyone has found that information.
Thanks
Never mind -- this was for a 370z (twin throttle bodies) -- apparently different....
I should have specified, I'm using the earlier single throttle body type.
I've looked at the FSM and I haven't found something clear for the pinout. The diagrams don't show numbers for all the pins, but it does show some, and ones that are tied together but are not numbered.
It is in the PC Link help file:
Thanks for that. I'll have to look at the help file.
