5v sensor wire
1999 Vistas
Can I run tefzel 20 awg for my 5v sensor and ground and also can I run 18awg tefzel for my 12v power to the injectors. Thanks again
Hi Darren,
You can use 22AWG for the sensor wiring. How many, how long a run and what sort of injectors (Peak & Hold or Saturated) are you using? A short run with 4 saturated injectors has a much lower current draw than a longer run with 16 Peak & Hold injectors.
