AEM X Series Connector Identification
632 Vistas
All,
I am using the AEM X-series water temperature sensor and broke the male 2 pin connector going to the sensor. I am new to searching digikey and am having a hard time finding the connector body with pins so I can replace the connection. I can buy the whole harness or harness from AEM but this seems more expensive.
It is the male connector in this AEM link below
https://www.aemelectronics.com/products/sensors/temperature_sensors/parts/30-2012
Any help would be greatly appreciated
Ben
The male connector (pins) is on the temp sensor. If you broke that, just replace the sensor.
I suspect you mean the female connector (terminals are sockets). That is a Packard metripak series connector. I don't believe Digikey carries Metripak. I suggest you look at Ballenger Motorsports. I think what you want may be this:
https://www.bmotorsports.com/shop/product_info.php/products_id/2306
Thank you so much! I am a bit of a newbie as is obvious by my mistake above. Appreciate your help despite my mix up
