BF Ford Territory ecu connector
1698 Vistas
Hi does any one know where I can get the “ECU” side of the main harnes connector for a BF ford territory/falcon.
I want to make an adaptor harnes to plug a Link extreme g4+ in the the factory ford loom for testing and so I can swap the territory back to the factor ecu at any time.
cheers Nathan
The easiest way to source one would be to find a donor ECU and remove the header connector.
Not sure what it's like in NZ but in Australia these ECUs are almost free and very commonly available.
Thanks for the reply I thought I may have to go down this route
yep old ecu should be easy to find here
cheers
