Connector Identification SR20
2162 Vistas
I am building an SR20 Wiring harness based on the Club Level wiring course. I am currently in design phase and filling out the document with all connectors/terminals and connections. I could use some help identifying some of the connectors in the harness.
I cant remember the exact name of the first connector you're put up, but its a really common alternator connector, so a google for nissan alternator connector will get you somewhere with that one.
The second one is a bosch minitimer 4-pin. Make sure you get it with the correct keying.
The last one I'm not too sure on unfortunately, its for the injector sub harness though? I'd go the route of replacing it with a DTM connector most likely.
