Connectors
1405 Vistas
For the splicing techniques used in this module (excellent by the way) What connector kit was used? I havent seen these splice connectors in standard electrical connector kits that I have encountered. Thanks.
Hi Abdel, I'm not 100% sure which module you're referring to. If you provide a link I'll be able to confirm exactly what Zac was using.
