COP Wiring
1471 Vistas
Just wanting to confirm prior to terminating my harness.
Seems to be two opinions on which way around these should be wired. Here is what I have planned, can't for the life of me get a 100% accurate pinout for these coils.
ECU is a Link Monsoon G4x, Picture of actual coils.
Have you tried testing them? What does the resistance measure between the pins? Are there any makings on the coil connectors (sometimes there is a "+" molded into the connector)?
On much closer inspection I have found the Mark's as you suggested. Thanks!
