Design a loom and future proof it.
Debate y preguntas relacionadas con el curso Cableado práctico para deportes de motor - Nivel Club
2767 Vistas
Hi guys,
I have a 4 cylinder 1.8L Mazda BP4W engine and I'm hooking a Haltech Elite 1500 onto it. Currently this is the stock engine loom:
- Cam sensor
- Crank sensor
- Ignition coil
- TPS
- Idle Air Control
- Coolant Temperature
- Air Temperature
- MAF
- O2S
- VICS
- Vehicle Speed Sensor
- Alternator Control
I plan to turbo and modernize the engine and take advantage of the Haltech as much as possible so I'm adding:
- Turbo, not aiming for big power so probably going with internal wastegate.
- Drive by wire throttle body and pedal.
- Wideband which will be connected via CAN.
- MAP sensor.
- LS Sequential Coil.
Overall this is what going to look like:
- Cam sensor
- Crank sensor
- Ignition coil
- Air Temperature
- DBW
- VICS
- Ignition
Wondering what else should I terminate right now to future proof the loom, what are you running in your car right now that I should add now or later down the road?
Best regards.
I call this "Futurability". A design that has futurability, has anticipated future needs by providing the possibility of connecting additional input sensors, or output controls. So you might want to just make additional I/O connections available for any unused inputs / outputs, typically this connections might also have appropriate power / grounds and would be labeled "Spares".
Then if you add a sequential transmission and need to add a gear position sensor or strain gauge shifter you will have a place to connect that harness addition.
A CAN expansion connection is another logical choice -- you might add a separate dash logger in the future.
If you think you might be swapping in a V6 or V8 engine, you might choose to make the Ignition & Injectors a sub harness that can be swapped out for a different engine.
Hi David, thank for answering my question, very appreciated. So I will split the rest of the spare digital and analog IO into a bulkhead that i can connect expansion loom to later down the road.
What's frustrating is I bought the Wiring and Tuning course expected to be covered 100% on installation of a standalone ECU but there is a big gap between them where they went from making harness straight to the software. If only they have a course that cover the function of the sensors.
